I was just looking at brewer's web site. I think the pic shows the bump in the bracket that Larry mentions. If thats the case placement would be a no brainer...Good Luck, Dan
http://www.brewersperformance.com/proddetail.asp?prod=FB470
The 68-69 B body doesn't have the notch in the frame for that tab, it will need to be ground off to get it to sit flat .
Also yes it has that access hole in the inner fender .
