Quote: Well, you can use the plastic straw to certainly get you to the obvious closest timing mark out of the 4 of them.
You can get it w the straw. We're wanting the correct mark (out of the 4) not finding exact TDC. unless they are real close (& unfortunately they are fairly close) & I'm thinking a PO made the 3 extra marks for certain degrees of advance that he was working with. 0632683" is 1 degree
