Quote: Go only with the Harland Sharps .650" offset or the T&D's. Hughes does not have near enough offset requiring a lot of grinding on the pushrod tunnel on the side of the intake port and the bottom of the heads. Saves a lot of agravation.
Had this problem with my Hughes rockers, I have 5/16" pushrods too. They are a nice setup, just require some more work.
