The car had patch panels put on the bottom of the 1/4's before I bought it. I didn't like how they stepped the weld seam. It looked horrible from inside the trunk. Plus it required a lot of body fill at the wheel lip opening. I was also worried about hidden rust comming through the lip from the outer wheel house. So I replaced the 1/4's and outer wheel house and trunk extentions.
