i had the same thing happen with an MP 484 smallblock cam .
you better get out the wrenches because when that happenes it stops the lifter from rotating and flattens the cam lobe in short order , the reason for your rough running issue .
motor has to come out and be completely gone thru , metal is everywhere
I don't think I damaged the cam yet. The lobe looks good. The motor hasn't run long enough to do any damage, hopefully
i'll assume you pulled the intake and took a good look at the cam ?
