If you are not sure on doing a clutch pedal swap even yet at this point, what you have in mind will be much more involved and will take a fair amount of your concentration, time and money to do properly. It would be a great swap if done right, but just make sure you are prepared to handle everything the project will throw at you is all...
Just saying that as someone who has done a few large build type projects. (and just on the downhill run of finishing a large build now)
