P/S Hose End Type : 5/16" Female S.A.E. x 3/8" Male Inv. Flare
Power Steering Hose Imperial Length : 34 1/4"
I found your description to match another one at NAPA that I can pickup.
http://www.napaonline.com/Search/Detail.aspx?A=NPS7610_0135925189&An=599001+101970+50020+2020006
That is a replacement pump and the hose was on the car when I bought it 9+ years ago.
I will trade in my current new hose for the hose with the above description.
Thank you
I just went in the my files and I saved the box top that my hose I used on my 68 Barracuda with Saginaw p/s pump about 7-8 years ago. It is Napa p/n 7-1574
http://www.napaonline.com/Search/Detail.aspx?R=NPS71574_0135925568
Now that I look at that picture I first posted, I like that 71574 p/s hose much better (NPS 71574). I know I'm using it on an A-body, But I have a NOS 71 Challenger p/s hose and it looks like the 71574. I think if you look for survivor 70/71 340 E-body with saginaw P/S pumps they will look like the 71574 hose.
The routing of you current hose into the P/S box looks a little wierd to me. Real tight between the box and the inner fender. Looks different than both new hoses were looking at online.
I've had problems with p/s pressure hose listings in the past. They don't seem to be right in the parts books. I don't trust them.
NPS 71574:
![](http://partimages.genpt.com/largeimages/947698.jpg)
