Do I tie the brown cranking ignition wire and blue running ignition wire together?
Also, can I join together both the black alternator wire and the red fusible link wires at the solenoid post? I am putting the heavy alternator wire to the solenoid post so do I need to run the black wire to the bulkhead connector or can I eliminate it?
If Crane wants full (no ballast) ign1 like MSD does then yes. Your running from alt "batt" to the large "batt" stud on the starter relay then from that terminal to the fusible link & on/thru the bulkhead to the ammeter? If so that is correct. the OE black output wire to the bulkhead, not sure if you can elim it even tho you ran the alt directly to the starter relay.
