Quote: Does anyone make an open end 5/8 stud lug for Weld Pro Star wheels?
If you bought the moroso or Comp engineering kit then they should of came with the nut's and aluminum spacers.
I did not buy the kit, the studs came on the axles I bought. Is that how the 5/8th work tho? There is an aluminum spacer that fits on the stud, inside the wheel and then a small acorn lug nut? I have seen those with some kits.
