My 72 Imperial is a CA car. It has a smog pump blowing air into the front of the passenger side manifold. I can't see where it goes into the driver's side manifold. The hose is disconnected and plugged. The manifold may have been swapped when they replaced the exhaust.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
