I have never used epoxy primer before and I have limited paint experience so tomorrow will be an experiment. Is orange peel typically an air pressure issue or mixture issue or both? What adjustments should be made when I encounter it? What do I start with? What is the sequence? Thanks
Gun is Devilbiss FinishLine 3 HVLP. Paint is DP90LF
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
