Yeah, you'll need more cam because assuming the same heads and cam the longer stroke/bigger cube motor would both lower the peak torque RPM and also (as a result) lower ther peak HP rpm as well. Normally as stroke goes up the gap in RPM between peak torque and peak HP RPMs narrows proportionally so you need a bit more intake duration to offset that.
WIZE
World's Quickest Diahatsu Rocky (??) 414" Stroker Small block Mopar Powered. 10.84 @ 123...and gettin' quicker!
https://www.youtube.com/watch?v=-mWzLma3YGI
In Car:
https://www.youtube.com/watch?v=PjXcf95e6v0
