Real simple here. Would my car be more fun to drive with a 5-spd Tremec or my current 904 with a GV setup? Which would be a better investment, the automatic, or 5-spd? Originality is NOT an issue here. Nothing original about my Charger SE mild small block car. Will the 5-spd give me more power than the auto w/GV? I know they are both strong setups but I'm beginning to think that my car's potential will always be limited in front of the 904 tranny? My Charger is a driver, and I want to drive it alot and have fun while driving it, including to start taking it on a couple of 2-3 hour trips each year. The GV has a .78 overdrive and the Tremec that I'm eyeballing right now is the TKO-600 with the .64 overdrive. The car will keep it's current 3.91 SG's. Which would you choose for fun, if you could afford either one? Thanks
