Looks nice! I forgot about them not having a mech. fuel pump.
Looks like you had to run a remote oil filter, as well.
mancini and hughes sell a cam snout extender to run a fuel pump eccentric on a magnum cam, so you can use a mech fuel pump with an LA timing cover like he's running...it's around $20.
oil filter is in the same place as an LA, ad the right angle adapter will fit a mag block, so you don't NEED to run a remote oil filter, but there's no way not to get oil on the headers when you change oil with it in the stock location.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
