Quote: Is there a problem if the front bearing retainer is smaller than the hole in the bell housing? I dont think the bearing retainer is any kind of supporting member, Im just curious. I thought I have seen factory bell housings with 2 different holes.
Kasey
Yes there will be a huge problem , why is your retainer smaller than the hole in the bell? When you dial in the bell you dial it in to that hole the bearing retainer fits snugly into , if the bearing retainer doesn't fit tight in that hole what's the point of dialing the bell in ?
