No intention to steal this thread, but I changed out the 284/484 MP cam in my newly built 451 low deck w/ 440 source kit & eddy heads, for an Engle AMC grind K56/K58 cam w/ 112 lobe separation. I wonder from reading this, if I made the right choice.
so if I'm reading their website right that would be 504/514 and 224/230 @.050??? should run good. What is the stall and gear? I'd think you'd need less stall w/ that cam than the 484 and you'd want at least 3.55's, 3.91's would work better.
