actually I did but now I find out that there is no bolts used, everything is studs with nuts. I finally got it right.
you could have just kept the first thread going instead of having multiple threads on the same subject , less confusing for everyone involved .
and there are actually 2 different size tube nuts , the one for the drivers side is SHORTER than the 2 required on the passenger side .
