Are you assuming this is the original motor? What's the engine code?
The '71 360 only came one way, 2bbl, single exh, low compression, small cam, 915 heads with 1.88 int valve (915 heads only had 2.02 if they were on a '70-'71 340), paint should be blue.
Maybe you have something better than original.
