i have an electric pump in my roadrunner. advantages, see above, disadvantages, feed back in the radio unless you have a modern antenna, buzzing noise in the trunk and having to be careful with fuel pressure.
They're also a lot more susceptible to rust and dirt thats in your gas tank, which can kill them pretty quickly. Its important to make sure you've got a clean fuel system before putting in a new electric pump.
That's probably what killed the pumps in our old Bobtail, three fuel tanks and NO maintenance and irregular usage.
Robert
i run a filter before the pump but in a stock motor there really is no advantage to offset the price and potential headache
