Just wanted to add, make sure the ECU has a good GROUND. A poor ground will shorten the life of an ECU too. On my drivers, I run one of those braided ground straps from a mounting bolt on the ECU to the engine block.
Is the voltage regulator suppose to be grounded also and not loose to the firewall or does it make any difference ?
logan426
Yes, the voltage regulator must be grounded. Also be sure to sand off the paint on its back side so it is metal-to-metal when titened down...
Just my $0.02...
