John,
Thanks for the input. The axles will be custom so that will not be a problem. If there aren't any issues with offsetting the pinion to center the housing, I personally would prefer that for looks alone. I'm wondering if anyone has had any problems doing that.
Arno
Actually, the center part of the housing is pretty well centered from the factory, the pinion is offset in the third member. Centering the pinion will move the center of the housing to the drivers side; hardly noticeable unless the housing is real narrrow.
The INTERNET, the MISinformation superhighway
