So basically replace the thick wires????
I can do that tomorrow that should cut down on the resistance right?
I'm thinkin that even the gauge might be the smallest point in the wire and heat up because the connections are so small.
Wrong?
has anyone ever had this problem before? How was it fixed?
if your dreaming of your car then it's your dream car....
