Speaking of torque boxes. Are they welded to the front, just inside of the frame rails? Or at all four corners, inside the frame rails? Also, I looked at AMD site and didnt see them. Its for a 71 Roadrunner.
No, outside frame rails, but inside rocker panel seams. This pic is of the left rear torque box on my '72 RR. It is looking rearward on the driver's side of the car along the seam of the rocker panel and floor panel. The holes at the top are to make it easier to get to the top two nuts on the leaf spring hanger.
Thanks Moparmarq!
