To start with the lock was stuck in the ON position. I was able to drill it out get it to the LOCK position.
We tore the column down and we were able to get to the ignition. There was what appeared to be a release on the bottom of the ignition when in the off position. We depressed the release and cannot move the ignition out.
Looking over the directions again it appears they want you to remove a spring. When looking for the spring we can only find a spring on the left hand side of the column. It seems like the ignition is still engaged. We are not trying to save the old ignition just trying to remove to install a new one.
Any insight would be great...
Craig
