Not sure about a Mopar but on my daughters 98 Lumina, pulling all the fuses for ABS/Brakes and pushing the brake pedal a few times and waiting a few minutes worked every time. Seems there is residual power you have to drain to reset the idiot lights. Unhooking battery might do the same as pulling fuses but for me with the battery buried pulling fuses was easier.
