I'm very impressed with the numbers guys are laying down with the E-heads!
I just want to put a solid reliable combo but I need to shift as much power upstairs (take torque off the bottom)
The combo will be:
4.06"
x 4" = 414
6.123 H beam rods
Flat top (JE's or Diamonds), should come up right at 12:1 for Zero deck
255/260 @.050 .568/576 Solid Flat tappet, 106/106
Eddie heads (the ones I have VJ/Bowl blend/pushrop pinch to ~1.02" (thanks for
the tip, Ryanj!)
1 5/8" A body headers (too small but they fit perfectly)
830 annular holley (was a tad too big for the 341)
Ported 340 Victor
Trans 904 with a 3500 stall T/A
Rear 8 3/4 W 4.56's, 295/65R15 M/T Drag radials
Weight right around 3000 w/me (245) in it.
going 1/8th mile, probably not enough gear for the 1/4 (like I need 4.56's now anyway
