Normally, a true 4 degree negative pinion angle is the maximum I recommend. This is relative to the transmission center-line, not to the driveshaft or the ground.
I like to see 2 degrees negative for a street car.
Over 4 and you are asking for a drive line rumble on the street.
true
for what is the good life if not doing things thoughtfully?
