...If the lever's below the pivot were longer, there would be a shorter stroke above at the lever. Does HURST or anyone else make a shorter stroke "SHIFTER" out there. I'm not going to have the Shifter-to-dash problem you have, but I'd like a little shorter stroke my self.
