I think a bottom end oiling mod is not necessary for a street engine.
I ran two separate oil lines from the sending unit to my turbochargers and didn't have ANY oil related issues spinning above 6000 rpm. I ran it like that for more than 10 years.
Run a decent high volume (NOT high pressure) pump and you'll be fine. Be sure your bearing clearances are where they should be.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
