The ProThans and Energy Suspension bushings are polyurethane. If you do decided to use poly bushings, you'll need to re-use the metal sleeves from the stock rubber inserts, just like with a trans mount.
Stock rubber engine mount inserts are available from the parts stores for about $15.00 each.
