Quote: NMCA and Mopower Events both allow 4-link setups.
NMCA maybe but not MoPower events
16. Suspension: Stock front suspension required. Front suspension limiters are not permitted. Solid bushings in rear suspension allowed. Leaf springs, if used, must retain stock length and mounting configuration. Leaf springs may be moved inboard for tire clearance. Ladder bars and coil over shocks permitted
Russ
Doesnt say they are illegal either .
I'm going to run stock front end with just a modified kframe... So I guess the fab 9 and 4 link is all good for running in that class.
