Quote: I was thinking you might need a Lencodrive or a Bruno to build boost off the line? Can you run Pro Mod or is this a Quick 8 or TS car?
the project was put on the shelf back in 2003 or 2004. The truth is that chassis might snap with that much power. not sure about getting into any races more like if it will ever get past doing 330' passes
