1969 HEMI cars have their own k-frame (skid plate & HEMI mounts) SPECIAL
1969 A12 cars use a mid-model year V8 k-frame (used '70 K-frame lower half with provisions for the "pass-thru" sway bar, yet retained '69 sway bar) not special
An early '69 model year V8 k-frame is different.
Ok, So I'm hearing you say that the A12 cars had a 1970 style K Frame, but the used a 69 sway bar whereas the 1970 cars used the same K frame, and a different sway bar? -Dan
Yep, and so did some later production '69 B-bodies or at least some later production '69 road runners that I've seen and owned.
MikeR
