The left Magnum manifold will NOT fit 67-76 A body cars, even with manual steering. the manifold body below ports # 1 and 3 wants to occupy the same space as the steering chuck. The outlet flange is too close to the firewall. The manifold MIGHT fit B or E bodies. I never thought to check.
I had a pair of the 92 magnum ones on my 68 cuda with manual steering
The turn off the left manifold was a little sharp but not bad.
