How do you identify them?I have a collection of 15" wheels and two of them have an H stamped between the wheel stud holes.I would like to identify the rest of them as well. Thanks!
the 69 H wheel doesn't have a part number on it , look at the inside of the wheel you'll see numbers stamped there there will be , the maker , a date code and the size , this will tell you what you need to know , post some pictures of the wheels if you want .
