So, from that article, a stroked 5.7 should do the trick? how do those motors swap out in a magnum? out the bottom? What needs to get done to the ecu?
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
