Hemi block is drilled for a 1/2" oil pick up tube, 440 uses 3/8".
Because of the heavier main caps, thicker main bearing saddles and extra material at the blocks corners to allow for the oil drain back holes, Hemi block weighs more, not sure how much, 40lbs?
