Check the lifters,they can uncover the oil galley if the lifter bores are not bushed. This usally happens at max lift, the window for the roller can uncover the oil galley and you will losse oil pressure.
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
