Hi,
Thanks for asking on Moparts.
Seat Covers: Legendary Interiors offers the best repro covers currently.
Dash Pad: Send your original to Just Dashes to be re-cast, quality is excellent.
Door Panels: This will be the hardest one...I highly recommend hunting down a nice used original set. Black sets survived the best and didn't fall victim to the UV rays as bad as the colored panels. You can re-dye the OEM set and you'll be very happy.
-Mike Mancini
You can also get a dash pad from
Ultimate Rides
11640 Gateway Eas
El Paso , Tx
79927
915-859-5155
I use them an I am very happy with there pads just get the metal backed ones and you will have to send them a core or be charged extra. You do have to do some minor trimming. If you use Just Dashes there is or was a long wait and the cost in my opinion is nuts.
I have used the Palco interior panels. Like above they can be a pain in the butt to fit but with patience and a little trimming here and there they will look decent. Like they said the grain is off a bit. I can send you some pics of the door panels and dash pads I put in a Cuda.
Seat covers definitely use legendary.
