no adjustment for slipping front clutches
if thats whats slipping
got a spare yet?
I went to Macon Ga. to get a 71 long tail shaft BB727 for a a999 hs/lu swap
how far is the band adjustment showing above the shift lever on it?
if its not a lot,that band has most likly been used up some with adjustments
the more threds showing the better
still if the clutches are toast no adjustment
how does the fluid smell? burnt? dark color?
leaks and low on fluid?
found a spare yet?
dont know much about them,but have changed a lot of them in just about every thing that had them, since I was 16 and
good luck with it
good times are when they are "used" and work
but i have changed a couple 2x cause they looked good "used" sitting on some shop floor and no worky..
