Quote: Then it has to be the magnetic pickup in the dizzy, either out of adjustment or the the pickup itself somehow got toasted when you had yer short....
As was stated earlier in the thread he is only getting 60 ohms at the pickup. That is way low. Should be 400-600, and with the meter switched to volts one should get at least 1 volt AC when spinning the dizzy.
