I trimmed the stock radiator brackets off the core support then fitted it up to see where everything is at. The support now sits 1 3/4 inches foward of the original location. I need another 1/4 inch to get good clearance between the fan and radiator. I do not have a condenser yet, eventually it will get a vintage air or similar setup. How thick is a condenser? Should I go foward another inch and hope for the best or give myself 2 to 3 inches?
