The wiring is all the same on the motor but 70 & 71 models used a variable speed switch and the 72 - 74 used a dedicated three speed switch. There wiring into the switch is different with 70 - 71 switches using two separate connectors and the 72 - 74 using just one. Same wiring on the main wiring harness, just different individual connector locations.
Slotts
