Correctly set up rear axles are completely silent.
But a slight error on clearance or in the manufacturing of the gear set can cause some normal noise.
taller (large number ) gear sets are more likely to have some noise.
A better description of the noise would help, such as whines on acceleration, decelaration, or simply gets louder and faster as you drive faster. Each case has a typical reason..
