I have a set of 72 spindles on my car I got the rotors from the local partshouse, they werent 2 piece and werent cheap but they worked and the car stops fine
If you are running the one peice cast rotor on the spindles that came with two peice rotors,then the daimeter of the shaft is smaller than the spindle than the spindle that is correct for those rotors. They will bolt on,but the inner bearing is only contacting on the inner edge if the race.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
