Easy stuff.
Find a used, low-mile 5.9 Magnum from a truck, maybe even from an 'R/T' if you're lucky, it should be bolted to the OD trans already. How easy is that?
Trouble is, magnum 5.9's are 1992+ but the 1996+ transmission is not usable because it's electronically controlled. He may have to do a bit of mixing and matching across a few year span to get the right year transmission with a decent shape 5.9 magnum.
Okay, unless i am reading you wrong, that still leaves the 92-95 5.9 complete set-up. Thats four years. This stuff isn't rare by any means. If you cant find it you either live in Whitehorse or aren't looking hard enough.
Mix and match is fine too though. I'm just too lazy to do that. Thats 9 or 10 more bolts i dont have to turn... haha.
