For the small amount of tub you could stuff in there , I don't see this as being very beneficial. I used around 80 inches of 3" X .060 cut in 12 to 15 inch strips and got about as much room as you're gonna get in there. It would be easier and probably cost about the same to buy a Chi com bead roller and make your own tubs , because you will be cutting away most of any aftermarket tub that I am aware of.
