Surely you must be talking about the distributor end of the wire pulling apart? I would just recrimp them. When you buy the universal set (cut-to-length) you do your own crimping.
Nope, talking about the 90* boot on the spark end. Happened on two of the 8. I went to pull the wire off (from the boot, not tugging on the wire) and the terminal stayed on the spark plug. I recrimped them the best I could seeing as I don't have an actual spark plug wire crimping tool (ordering one today) and they seem fine.
It wasn't the universal set- it was the premade Taylor Spiro-pro 74072 premade.
