Thanks! When swapping on the magnum heads,which pushrods should I use? I remember reading somewhere that the magnum heads are oiled diferently than the old school la heads. I also remember they respond well to port work. Iam no porter by any means but iam capable of some minor gasket matching and cleaning up the bowls. Is it worth the aggravation? Or just bolt them on and gas it!!!!!!!! Thanks again!
Use pushrod oiling and the best bang for the heads
is to do the bowls and just clean the runners
