Despite the above statement the earlier 360 blocks are slightly better in general thickness wise. They will also have closer to 8.3 -1 comp vs 7.5 on later 360s. I can say this much, if the 79 is a E58 360 get it. It is one of the better engines out there and if done right will give you a long life span and no trouble
